ORIGINAL: F-15 Fan
YES!!! Thats it.
You know what I should do?
Did you read post #14?
Install the prop stud fully. Slide the prop dive collet on the prop stud, then the prop drive then an old prop. Then add the prop washer and nut and tighten down firmly. You will NOT hurt anything. It should seat the collet in the rear of the driver.
