RCU Forums - View Single Post - NQD Hydro
Thread: NQD Hydro
Old 11-05-2007 | 08:23 PM
  #457
ryan_t888's Avatar
ryan_t888
Default RE: NQD Hydro
EDITED FOR DELETED PREVIOuS POST
Simon,
I would consider picking up a Graupner 700 8.4v BB motor and a flex cable, .150 with 3/16 prop shaft over a straight shaft. Then use a 3/16" strut. The prop center line should be close to the bottom of the rear ride pads or even slightly below/above. You may angle the prop slight downwards. Start with an Octura X440. Water cool the can and brushes on the motor.
On 12 cells, you should be around 25mph.
Ryan
