RE: will a chicken stick work?
the chicken sticks works i used one for a while the first start of the day is a little hard but after it warm 2 or 3 flips and your golden.
also put your engine in the decompersion cycle you should be albe to move the piston up and down easy. mount you prop level with the ground. this wya when you dead stick in grass you dont have to worry about catchin that prop
