vnmsgt:
thanks, acually it isn't at all. being that its a truggy, it has a really wide track therefore it doesn't matter a whole lot. and it also handles GREAT even with the packs up there.
thopper:
it has massive braking power being that the motor is made for torque. i'm sure you could air correct, again because the brakes are so good.
the pinion is a Mod 1 pinion from RCMonster. as for top and bottom end, it has MASSIVE lowend. like huge torque. the batterys are normal 3300s donno the amperage on them.
yes that is the stock center diff. thanks
chrobar:
as i told vnmsgt, no there not too high. doesn't effect the handling at all. and no, i tryed and there really isn't another place to put them. atleast with even weight distribution.
thanks for the questions guys,
Aaron
