RCU Forums - View Single Post - BLADE DANCER - MS Composit
Old 11-06-2007 | 12:29 AM
Coonak
Default RE: BLADE DANCER - MS Composit
ORIGINAL: trevormatney
Hi! I had an ms composit UNIQUE, which most likely uses the same building techniques, and cruddy instructions. On the UNIQUE, the string was used as a spar for the wings, and for the fuse sides as well. If I recall you are to cut a slit in the wings where indicated in the instructions, then push the string into the slit/slot, and finally fill the slit with CA soaking the string. Same operation on the fuse. Good luck bmoran!
Trevor
Yes you are correct!
I know a few guys that own these and they substituted the string for Carbon Strips.
I have the MS Composit Boom, (Same plane diff paint job) and i used the string, it worked fine.
Mick
