RCU Forums - View Single Post - Walkera Dragonfly #36
Old 11-06-2007 | 08:31 AM
  #9646
helifan06's Avatar
helifan06
Default RE: Walkera Dragonfly #36
ORIGINAL: cu19x
ORIGINAL: Rollin Thunder
Use the 4th hole and cut the rest off. Am I the only one not using extensions on this servo?
Hello to everyone and keep the good information job for us
Sorry about my English. They are not quite good
I have post this again in another thread but i took no answer.
I have a walkera 36 and i did some upgrates like metal swashplate and tail rotor, carbon blades. I bought the walkera 3200 20-001 brushless motor and used the pinion that already had in stock with the brushed motor. I saw that the heli hasn't got to much power as i thought. I have a 40 amp speed controller and a 2200 li-po battery.
I want to gain power and i want some suggestions about buying new motor and speed controller and pinion if i must have something else.
I think the gyro is quit good and don't seems to want upgate.
I also want to buy new servos (cause the tail servo is just a toy).
Can someone help me if i did something wrong with the motor-speed control-pinion choice and if i have to buy something else. Which is the best buy concluding servos and li-po battery
Sorry if i make many and silly questions. I am a beginner but i want to learn correct.
Go with Align 430 motor; and speed controller. You can find it on helidirect.com. For the servos; you can use HS56; or if you have a 401gyro; you can use a digital fast response tail servo. I'm thinking of changing the tail servo on my Trex too.
