RCU Forums - View Single Post - Engine Problem
Old 11-06-2007 | 09:08 AM
bkdavy's Avatar
bkdavy
Default RE: Engine Problem
ORIGINAL: mouthpiec
And regarding the cowl, there is a hole on the side, and adjustments are made easily.
Remember the adjustment I'm talking about is the small screw that is inside the throttle lever, not the high speed needle adjustment. Its not clear from the pictures that you have access to that screw with the cowl on. Just checking.
Assuming you purchased the engine from a dealer, not second hand, I wouldn't plug the hole. The designer put it there for a reason, and modifying it will probably void the warranty. If you reduce oil flow to the front bearing, you'll greatly shorten the life of your engine.
Brad
