RCU Forums - View Single Post - needing help
Thread: needing help
Old 11-06-2007 | 09:25 AM
blw's Avatar
blw
Default RE: needing help
It is almost impossible to get an accurate temp reading on glow engines. Plus, your external readings won't mean much regarding what the temps are inside of the engine. It is best to ignore temperature readings and concentrate on propping the engine correctly, and tuning the needle valves. What size pusher prop are you using?
