RCU Forums - View Single Post - For .6 ohms application foam cutter
Old 11-06-2007 | 11:10 AM
seanreit's Avatar
seanreit
My Feedback: (60)
Default RE: For .6 ohms application foam cutter
So if I use a dimmer switch on this transformer and not go over 4.8 volts, I'll be within the limits of the transformer. And then the question becomes 38 watts, and will it be enough to cut foam with this custom tool I made, probably not.
