RCU Forums - View Single Post - Are all trainers trikes?
Old 11-06-2007 | 01:05 PM
outdoorhunting
Default RE: Are all trainers trikes?
A 4* 60 is probably the closest tail dragger that could be called a trainer. If you start with that, you'll save yourself the price of the tricycle- highwing to begin with & you would probably be buying the 4* for your next plane anyway. The 4* is probably, no, it IS the most forgiving low-wing taildragger on the market.I would almost guarantee you if you started with a 4* you would learn more & faster than if you started with a high wing.. AS LONG AS YOU HAVE A GOOD INSTRUCTER !!! Good luck & good flying Remember try to always land with the wheels on the bottom!!
