RCU Forums - View Single Post - Aurora 60 Plans?
Old 11-06-2007 | 04:08 PM
  #88
cam-flyer's Avatar
cam-flyer
Default RE: Aurora 60 Plans?
CA glue in some 1" triangle stick. Use P1 to get the center location. Use a clamp to get the angle and only glue where the sticks cross and where they touch P2.
P1 is a departure from the original nose opening look because of ease and engine selection. However, if you want to build-up the more triangler look nose, move the triangle sticks back as for as the engine will allow and fit P1 at this location. Add balsa to shape the nose for the ply wrap.
ID:	798329   Click image for larger version
ID:	798330   Click image for larger version
ID:	798331   Click image for larger version
