RCU Forums - View Single Post - Engine Problem
Old 11-06-2007 | 11:59 PM
OzMo's Avatar
OzMo
Default RE: Engine Problem
Hi mouthpiec,
one of the most aggravating things I have run into is a simple worn out O ring on the needle valve. very hard to see, but you can SOMETIMES tell if its bad by gently wiggling it when the motor is running you will see air bubbles entering the fuel line. This can be very intermittent.
