RE: JR XP652 how to Aileron & Rudder identical
You don't need an aileron to rudder mix, you need a rudder to aileron. You need to go to a program mix, set the master in the mix to rudder and the slave in the mix to aileron. The first channel in a mix is the master, the second is the slave.
