RCU Forums - View Single Post - Fuel Clunks
Thread: Fuel Clunks
Old 11-07-2007 | 11:40 AM
Bob Pastorello's Avatar
Bob Pastorello
My Feedback: (198)
Default RE: Fuel Clunks
ORIGINAL: RTK
aerobob-- There was a thread here on RCU a long time ago that debated this. Some aerospace guy said that the gas in the tank "tends" to stay in the back on a down line and he had some video to show it. As you mentioned a down line at low throttle setting should not empty the line even if all the fuel went forward.
The example I mentioned happened more than once to me. The knock off tygon went stiff, as in solid, in about 3 months on one of my planes. When the tank was less than half full and you did extended inverted flat spins the engine would die. When I finally decided to look at the tank, the clunk would not move from the back bottom. It would take a while before it died..
I appreciate that info, really! I do not doubt for a minute that your experience is valid, and probably was not a happy discovery.... I like to understand the "whys" of things, and this fuel klunk situation it one. It is SURE important the klunk can move top/bottom/left/right at the back of the tank, for sure.
Thanks again.
