DP 330l
i am at 6 1/4 i am not pitch senstive.
I run the following for low rates
10 degress elevator, 25 rudder/20 degrees ailerons the other rate are 3d as follows:
40 degress elevator
40 degrees rudder
25 degrees of ailerons
at this rate my plane still dives a little inverted, i will be moving the cg on back to achevie hands off inverted. As long as you are not banking and yanking the elevator stick 10 degress you will find will work with just about any aerobatic ship.....
