RE: Adjusting blade tracking
After adjusting - new spindle - flybar is centered and level.
Also, Splat - I believe you bring the high blade down - however, there comes a point where both blades might be too low, and it would take excessive headspeed/throttle to get it off the ground. I will measure the linkage length against the manual (darn, need to get a good dial caliper!!)
