RE: sprockets
Patton, how about modifying the pzIII sprocket, clip off the outer portion, sand the facing flat and this will give you a hub to screw/glue a smaller, scale detailed sprocket to. You could probably use a thin washer and use a dremel to make the teeth. Just spit balling here....
