RCU Forums - View Single Post - erratic Tower 75
Old 11-08-2007 | 01:39 AM
alan0899
Default RE: erratic Tower 75
G'day Mate,
First off, get rid of that plug, use an OS #8 or equivelent, richen your top end, it should gain a few revs when the nose is held up, if it is rich enough, & if the midrange is rich, you need to lean you low speed slightly & do the pinch test at idle.
I assume you know how it should perform, when doing the pinch test.
