RE: Is this normal?
pywackit- good thing you checked. Glad the engine is running fine again
rainydave- that is exactly what happened. Yes, they had more scan lines than we did. They also had a better color range (gamut). You can see our limitations mostly on reds. Look at live shots and you will probably notice shimmering colors. Those are the incompatible ones. Hollywood has technicians to select only the right colors for filming. I don't know how HD is progressing in Europe.
