RE: J3 cub, crash on take off nearly every time.
Hey JPANN,
I have followed the thread from the start and before I'll give you some suggestions I would like you to give me some answers in my following questions...
1) Did always the plane had the tendensy on one side on its short flight? and which side was this?
2) Did this tendency increased as you increased the throttle?
3) Have you tried to idle the motor while it was 2 mistakes high to see the tendencies applied on the plane?
4) If your throttle was stable was the tendency the same when it was crosswind and downwind?
5) Did you have any side thrust and down thrust on your motor mount?
I think that I have some good answers to you if you provide the desired info...
Awaiting of your reply
BR
Johnnie Red
