RCU Forums - View Single Post - base loaded whip antenna installed inside jet
Old 11-09-2007 | 11:28 AM
CARS II's Avatar
CARS II
My Feedback: (7)
Default RE: base loaded whip antenna installed inside jet
Install it in the fuse standing if can ( you should have plenty of room ) when you do your range check with the engine running ramember to move the jet around so you get to test the singnal streng from 4 diferent positions to see if your range is ok.
Best way for your set up is to have the radio wires and reveiver on one side of the fuse and the turbine wires and electronics on the other.
Good luck on you maiden.
