ORIGINAL: ehroof
do thicker in the center, like 7front 10 center and 3 rear, this way the front will grab more.
the thicker the center the more the front grabs and pulls you around the corners, thick in the front and rear will make the front or rear tires be more of a posi.
That is how I have it. 7 front 10 center and 3 rear. I think I just worded it wierd above. What do you think of this comment I got in the truggy section:
"right now your front is too thick. with 10k in the center and 7k in the front the center can't spin the front as easy as the back. so your getting a little too much power to the rear. most of the time you should run 3-5k up front. a good starting point is 3f-10c-5r. you want some powerup front and a little more in the rear. right now you have it backwards. understand what i'm saying?"
