RCU Forums - View Single Post - New Brushless DF Board Soon Available !!
Old 11-09-2007 | 10:15 PM
Old Man Mike
Default RE: New Brushless DF Board Soon Available !!
ORIGINAL: Blackdragan
Mike,
Are the ESC's wires long enough to be reach the (8 pin) motor connection on the bottom of the board or do they have to first be spliced to the original wiring harness?
John
If you are using the existing DF frame, you really don't need to use the 8 pin motor connection at all. It is best to just wire all four ESCs directly to Battery Ground (Black Wire) and after the positive side fuse (Red Wire). The servo wires from the ESCs are long enough to reach the front pins with no problem. You can actually save some weight by removing the original connector and wiring harness (and even the Hexfets if you want to bother with unsoldering them from the board). While you could use the motor harness wires, the total resistances is greater plus you will have more potential noise conduction to the 5 volt supply thru the Hexfets. That noise is believed to be the source of the infamous 0.8 sec dropout so eliminating it is a big plus.
Mike
