Well the "Builders Kit" arrived today and for the price it is impressive and better then i thought it would be
The Cabane wires are pre bent and also soldered quit nicely. The Canopy is clear with out a scratch and wrapped in plastic to keep it that way. With just a little studying the plans are easy to understand and clear for the most part. You are also provided with a short manual with out pictures but it reads as though it will get you over the sticky parts of the build. The Landing Gear is bright shiny aluminum with no pre drilled holes.
There really is not that many parts that need to be made to make up the kit. After studying the plans it looks like it will be a fairly easy build if you have some experience building kits.
Im not sure but i think the plans are scaled down from the original soultion x plans. I'll be comparing them to the full size tomorrow.
As soon as i get all the parts cut out and sanded i'll start posting pic's of the build
Pat
