RCU Forums - View Single Post - nitro models 50cc yak??? the good/bad/ugly???
Old 11-09-2007 | 11:49 PM
cjembree
Default RE: nitro models 50cc yak??? the good/bad/ugly???
Nitro Wing
The cowl diameter is 10 1/4", the wing span from my measurements is 85" as stated on the nitroplanes site, the fuse length is approx 77" from front of cowl to tip of rudder, the landing gear is aluminum and seems good and strong, the control horns are as I mentioned before similar to the ones used on the aeroworks arf's (dual metal horn for each control and 4-40 ball links and rods) seem very usable, I will use them for sure. Regarding the canopy attachment, I presume you want to know if it has dowels for the front which it does, and has two tabs (mounts) on either side near the back that is bolted from the outside. The canopy itself is not glued in place, you have to do this either with ca, or canopy glue. The hinges are large robart style pin type that are not glued, which I prefer to do anyway (rudder has 4, elevators have 4, wings have 5 each).
