RE: Digitech anouncement and offers
Sandor,
Thank's for the info. I was on the verge of ordering the advertised as Elan main struts from Jetpower, but was not aware that modifications would have to be done.
Since I have already modified a set of Robart 630 retract units I had on hand to fit the rails of the Elan, I simply am looking for the Jet-1a struts that will drop in the 1/2" diameter trunion block without having to use a pin to adapt, and not have to modify the gear well opening.
From what I have seen, all of the original Jet-1a struts designed specifically for the Elan require a pin for adaption to the retract unit. In short, I want a set of Jet-1a mains and a steerable nose gear that will fit the Robart 630 trunion block and not have to modify the gear well. Are these available?
