RE: TT .91F Pre-Ignition "Girgling sound while flying"
Are you running the choke adaptor? Without it the engine will not draw fuel well. This will make it lean out in flight. If not enough to make the engine quit, then possibly enought to make it detonate. The manual doesn't tell you this, but unless you are using a pump or regulator you need the choke adaptor.
