RCU Forums - View Single Post - jittery servos
Old 11-10-2007 | 04:18 PM
jetmech05
Default RE: jittery servos
if you're that close you're probably over driving the receiver...keep your antenna down and get about 15 ft away..see if it stops..if so a range check should be done close your antenna and walk....you should get 75 to 100 ft away before the control surface gets jumpy..stop and extend the antenna ...normal control should resume
