RE: How do you work with GP hinge slot machine?
I've found that it works best if you mark where you want the hinge with the tool that was mentioned avove.. then, turn on your slot cutter and place only the left or right "corner" of where the cutting happens into your balsa first, then slide the rest of the blade in carefully..
