RE: I need help
With regard to rates, maybe this will help. Say the radio is set for low rates. The ailerons/elevator/rudder will move a max of 25 degrees (assuming that's what it's set for). When you flip the switch and use high rates, they will now max at 50 degrees (again, depending on the setting). It basically just gives you multiple levels of maximum throw on the servos.
