RE: Team Associated RC18B Pro Kit or Duratrax Vendetta?
I would really recommend you get the aluminum steering linkage from integy. Then on the plastic servo saver, I glued the plastic spring to the part that goes on to servo, with a mg servo the steering is perfect and over 1 year with no problems. On my other 18b i have the aluminum steering linkage, but instead of gluing the servo saver together, I cut a piece of old 1/10th shock spring, put it around the plastic spring, and touched it with solder gun to melt it into plastic. Works good.
