RE: Trouble running in hard turns
Clunk orients to the REAR of the plane and should be free to move side to side and up/down.
Conventional venting will lean out somewhat as fuel level goes down. You may need to go a tad richer on the ground setting since the motor will unload in the air going leaner. Additional leanness from conventional venting fuel use can make you over lean.
