Lining Up Templates on a foam wing for hotwire cutting???
Draw a center line on the template from center leading edge to center trailing edge. Use that line measured from the table to get the right placement for height and wash out on the foam.
I hold them on with small nails, but watch that they are in the foam and not in the cut line. Hot wire won't cut nails.
