RCU Forums - View Single Post - warhead evo?
Thread: warhead evo?
Old 11-11-2007 | 02:47 PM
motodude11's Avatar
motodude11
Default RE: warhead evo?
I think this is a great truck you just have to get to know it, taking it apart is a pain the first time but once you figure out what order to takes things off its a breeze. Even with the problems i've had I still love it because something goes wrong you just call duratrax and they replace it for free if its not your fault. I've only had a few problems with the truck but im sure its do to me not going over it before using. The first problem was the topshaft gear had the pin break on it into three pieces. The last problem was the CV joints dogbones were wearing fast, and it blew a pin in the lower joint, but after a talk with a technician at duratrax they told me that it was because my truck was set up in rumble mode. They said that the angle that the CV joints were at that there was too much added stress on the trucks CV joint components and that they will always abnormally wear unless you keep the truck at factory settings. This is a fast truck although it wont do wheelies, it is made for racing, it has excellent handling and after some hop ups this truck is really insanly fast. I have Aluminum transmission cases front and back, aluminum bulkheads front and back, aluminum clutch shoes, aluminum steering bellcrank, aluminum draglink, ultralight clutch bell, and reverse eliminator, and i removed the shifting servo. I also noticed that the aluminum steering bellcrank and draglink produce a much better handling truck. JM2C and i hope that i helped save anyone from any unneeded aggrivation.
Josh
