Finished the lower hull.Installed the on off switch,main board,built battery compartment,attached battery and soldered all the lower hull connections.Test run was good,run it all over the house.Did turns,fast spins,forward and reverse.Did notice it runs faster backwards than it does in forward,don't know why.Looking at any track resistance it would apear to be the other way around,this could be due to the weight distribution factor being heavyer in the front.Only part left is to figure out how to mount the gun elevation motor,headlights to wire,and general wire layout in the upper hull and plug in.Also installed a charging plug on the back of the lower hull. Pictures to follow--BIGMIG
