RE: How Best To Fix This Tail (4*60)
I'd use the tri-stock on the inside, and then use fiberglass on the outside. Get the lightest cloth you can find, use 30 minute epoxy, and put on two layers of cloth. The final result will probably be almost completely unnoticable unless you look really close, and will be plenty strong.
Brad
