RCU Forums - View Single Post - Black Magic VF3 Build Thread
Old 11-12-2007 | 12:23 AM
  #150
handglider's Avatar
handglider
My Feedback: (23)
Default RE: Black Magic VF3 Build Thread
Landing gear block doubler
Locate these cool carbon composite doublers, they will need sanded a bit, mine had some CNC flash. Trim the balsa flooring at the block, make it a nice fit. I roughed up the mating areas of the main doubler and clean it with acetone. I used west systems 105/206 for the block doubler.
First install the block doublers. Then fit all the balsa flooring and CA with thin then follow gaps with thick CA. I run a bead of thin CA on both sides of the flooring.
ID:	802019   Click image for larger version
