RE: Black Magic VF3 Build Thread
Fuse bottom cross bracing
Once your block doublers have set and you can flip the plane over you can install the 1/4" balsa cross bracing. Use nice lite stock and a fine razor saw. Takes about 5 mins to do this step. I first use a good drop of thin ca and follow up with a good drop of thick ca at each joint.
