RCU Forums - View Single Post - Black Magic VF3 Build Thread
Old 11-12-2007 | 12:43 AM
  #152
handglider's Avatar
handglider
My Feedback: (23)
Default RE: Black Magic VF3 Build Thread
Fuse top bracing
Okay once the bottom is braced. Flip her back over and install the top cross bracing. Epoxy the stab adjuster rod in place and install the fin plate at the rear of the fuse.
Note - if you plan on installing a deps system, install it before you add the top cross bracing. I am about to install a deps in the twin vf3 and I'll post pics of that. I am going to use the set up that Mike uses on his deps set ups.
I'll also be using the Bondable Teflon Sheathing for the deps instead of the material central provides in the kit. I used this stuff on my v2 build and it works great. It bonds so well you just ca it in place and you can't pull it off without breaking the former.
You can get the Bondable Teflon Sheathing from - http://www.cstsales.com
