RCU Forums - View Single Post - Black Magic VF3 Build Thread
Old 11-12-2007 | 01:04 AM
  #155
handglider's Avatar
handglider
My Feedback: (23)
Default RE: Black Magic VF3 Build Thread
Fuse top etc....
Okay we are making good progress here.....
Once the top turtle deck core has cured install the front carbon turtle deck former, I used a thin layer of 5 min epoxy.
Now install F2T - the top former above F2 - Use a piece of 1/4 stock and lean it forward so it's 6 5/8" from the firewall. Epoxy in place.
Install F3T and F4T with epoxy.
Cut and fit the top side 1/4 stringers that run from the firewall , across F2 - F3T - F4T and then into the top turtle deck. Cut a slot to recess the rear 1 1/2 or so into the top turtle deck. Once in place you need to cap it with a bit of 1/16" sheeting wood.
