well there are two dif kinds
the Master's and the Elite
the Elite are sold at Target for like 49.99 which are the ones shown in thoes videos, i had they are ok, i supped mine up, u can see my videos in the "related vide section off that link" but the stock dif blew up
Tower is selling the Master's and are now avaible they are like 67 bucks, i think i might pick one up to see what that is like here are the specs
http://www3.towerhobbies.com/cgi-bin...&P=IA&I=LXRNU2
http://www3.towerhobbies.com/cgi-bin...?&I=LXRNU1&P=M
Specs on each type
Elite:
RADLINE RC’s ELITE SERIES---fast, fun, responsive 1:24 scale vehicles that prove big things can come in small packages! With all the excitement, detail and technical innovation you’d expect in larger scale, our All Wheel Drive ELITE SERIES is equipped to compete---right out of the box!
SCALE: 1/24
TRANSMISSION: 4WD
TIRES: Off-Road w/foam insert
SUSPENSION: 4 Wheel Independent Wishbone
PRE-INSTALLED MOTOR: 21,000 RPM FC-130
SPEED: Up to 240 scale MPH
RADIO SYSTEM: Race up to 6 cars at once---AM 3 Band, 2 Frequency (29 & 49 MHZ)
TRANSMITTER FEATURES: Steering & Throttle Trim, Band Select, Torque Control
RECEIVER & ESC: MOSFET Power Control IC, Over Current Protection Circuit, LED
Band Select Indicator, Band Select Switch
CONTROL PROFILE: 31 Step Digital Proportional Steering & Brake
CHASSIS: RADLINE RL4
POWER SOURCE: Transmitter 1x9v, Car 4xAAA (*Rechargeable batteries recommended)
AVAILABLE EXCLUSIVELY AT TARGET stores RETAIL $49.99
Need even more excitement? Check out our UPGRADE & REPLACEMENT PARTS!
Masters:
RADLINE RC’s MASTER SERIES---If you’re an experienced RC enthusiast looking to really compete, give our MASTER SERIES vehicles a test drive! Their “Master” grade components deliver a faster, more maneuverable product you can modify and maximize into a true high performer!
SCALE: 1/24
TRANSMISSION: 4WD
PRE-INSTALLED MOTOR: Hi-Rev 180
SPEED: VARIABLE (Dependent on motor type used and installation of performance components)
RADIO SYSTEM: Race up to 6 cars at once---FM Transmission, 6 Band, Single Frequency (27 MHZ)
TRANSMITTER FEATURES: Steering & Throttle Trim, Band Select, Torque Control, Steering/Throttle Reverse Switch
RECEIVER & ESC: MOSFET Power Control IC, Over Current Protection Circuit, LED Band Select Indicator, Band Select Switch, “One Touch” ESC Throttle Setup, 3 level Brake Strength/Motor Frequency Select, No limit to 130 Type motor upgrades
CONTROL PROFILE: 128 Step Full Digital Proportional Steering & Brake for precision control
CHASSIS: RADLINE UL-01ST POWER SOURCE: Transmitter 1x9v, Car 4xAAA (*Rechargeable batteries recommended)
PERFORMANCE UPGRADE FEATURE: Factory Installed Ball Bearings for friction reduction, chassis can accomodate FC-130 and Hi-Rev 180 motors using included special adapter sleeve
AVAILABLE AT FINE HOBBY RC STORES NEAR YOU---RETAIL $89.99
Need even more excitement? Check out our catalog of UPGRADE & REPLACEMENT PARTS
i think im going to pick up one of the masters at Tower to check it out,
