RE: Pull Starter
take the pull start off carefully and pull out the bearing and I use orange 406 to clean bearings then use bearing oil to lubricate after cleaning but there are many ways to do it and im sure someone will tell you im wrong to do it there way but you cant pretty much do it however you wnat just make sure you lube it before you put it back in and make sure you watch how it comes out and make sure it goes back in the same way
