RCU Forums - View Single Post - Balsa USA Super Cub Build
Old 11-12-2007 | 04:53 PM
  #154
Tony Hallo
Default RE: Balsa USA Super Cub Build
Here's the floor just about complete, I will finish the floor natural with varnish, all the tubing will be painted flat black after it is glass bead blasted. On to the throttle, carb heat and trim controls. I also need to complete the fuel tank installation, I will be using two Sullivan 10 ounce oval tanks hooked up in a hopper arrangement, the tanks will be located in front of F2 former on each side of the fuselage.
