Four*60 elevator troubles while finishing
while I try and insert the connector piece. I obviously drilled one of the holes off line, and now the two elevators don't line up on a flat surface.
Can I wallow out the hole to make it line up or should I twist the connector rod until it lines up with the elevators?
Hope I made myself clear. When the two wooden elevator halves are connected with the metal rod with two bend in it, one of the elevator halves is twisted upward.
TIA
Philip
