RE: Four*60 elevator troubles while finishing
Thanks for the suggestons. I think I will fill the hole with balsa dowel made by chucking a small square piece in my drill and turning it with sandpaper until it is dowel shaped.
I plan on lightly sanding the metal connector to help epoxy stick and then covering the wood to metal axle area with fiberglass soaked in CA as per instructions.
Thanks Philip
Hope to post some build pics soon.
