RCU Forums - View Single Post - Four*60 elevator troubles while finishing
Old 11-12-2007 | 09:55 PM
chashint
Default RE: Four*60 elevator troubles while finishing
If I could not bend the wire to the correct angle I would wallow out the hole and just add extra epoxy.
If the hole breaks out I would just put a thin piece of fiberglass over it and CA or epoxy it in place then sand it using Balsa filler if I had to.
If it turns out tail heavy just mount the engine a little farther out on the beams to offset it.
