RE: not again!!
i believe that the mini baja is a little faster but the mini quake looks more rigid and range depends on what radio you buy if you get the SE but my mini baja has gone to like 200ft or so... not sure about the normal mini quake though
dacaur"Mini baja is one I would think about... 2.4Ghz and lipo would be awesome.... but doesn't have the warranty, and its over your budget... with the mini quake you have money left over for a quick charger...
Mini-t is in a different class, 2wd, i wouldnt even consider it,..."
the mini baja is a mini-t pre modified and does not come with lipo or 2.5ghz, it comes with a 27FM sythesized radio and a 1100 mah battery.
