Smaller props load the motor less because they produce less drag as they pass through the air. By the time you run a small enough prop on that motr all you will have is lots of prop speed but not pure thrust. By using a gear box you can swing a larger prop at a slower RPM and it will work much more efficintly.
Stick 40
