RCU Forums - View Single Post - SPEED CONTROL
Old 11-13-2007 | 07:36 PM
opjose's Avatar
opjose
Default RE: SPEED CONTROL
Exactly.
That would be a fine motor for a ducted fan... but to run the larger prop, it would have to have fairly heafty coil wires ( which it does not ) to deal with the large amount of current the PROP causes the motor to draw.
In the "glow world", the prop is almost a secondary consideration....
In the "electric world" the prop determines how much current will be used by the motor.
Prop a motor wrong and you blow your electronics.
