RE: Black Magic VF3 Build Thread
Now go along the remaining formers install 1/4 sq support cross braces, all the way down to F8. Since you have tension on the pushrods and tubes, it easy to set the heights of the cross braces so the pushrods are as straight as possibe. You can view the pushrods from the rear of the fuse at F10. Once you are sastified with the positions of all the cross braces, hit them with CA and then CA the pushrod tubes to the cross brace supports.
ahhh - yer done and it takes about 15 mins.....
